Bob, I really like that idea. I am not sure it will work for me, but I will give it a try. And for those of you inclined to use vise-grips to get the troublesome screws out, this idea is brilliant! Bob, were you able to get SS cap screws?Bob Lascelles wrote:Once you get the screws were out, I found a quick fix was to replace the screws with stainless cap screws. I believe the screws are metric M4 x 8 threads. The socket head of the cap screws let you use an Allen wrench. You can shorten the wrench as needed to get behind the pulley and the socket holds the wrench securely in position for tightening/loosening. I think I got mine at McMaster Carr. Just a thought... All the best, Bob
REPLACING IMPELLER ON 1GM YANMAR FOR 25D
- tjr818
Re: REPLACING IMPELLER ON 1GM YANMAR FOR 25D
- Bob Lascelles
Hi Tim,
Yes, I'm using the SS socket cap screws right now on my pump and it worked out pretty well. I think I bought them from McMaster Carr. Like I said, I believe they are M4 x 8 mm (or maybe 6mm) 0.7 pitch. I can't find my old order, but McMaster Carr stocks a full line of metric stainless hardware. They're $6.72 for 25 in that size. I'm pretty sure have some extras around on the boat, I can check if your interested.
All the best
Bob
All the best
Bob
Bob Lascelles
CD25D Vindolanda #111
York, ME
York, ME
- tjr818
Bob,
As soon as I can get up to the boat I will check on the size. I think I need six, so I'd better ask for eight, if you can spare them.
- Bob Lascelles
Hi Tim,
I'll try to get up on the boat tomorrow (it's in the side yard). I'm pretty sure there's a small bag of them aboard. If so you're quite welcome.
All the best
Bob
All the best
Bob
Bob Lascelles
York, ME
York, ME
