Painting mooring buoys
jen1722terry
Post by jen1722terry »
Hey CDers!
I was wondering if anyone has found a bottom paint that will stick to the plastic mooring balls (Taylor Made type).
All advice appreciated.
Terry
Jennifer & Terry McAdams
Kearsarge, New Hampshire
Mahone Bay, Nova Scotia
CD 31 #33 "Glissade"
Jeff D
Re: Painting mooring buoys
Post by Jeff D »
The only suggestion is to roughen the surface with 100 grit first. I typically use whatever is left from painting the boat - I have used hard & ablative, water borne & solvent. They all seem to work OK.
jen1722terry
Thanks, Jeff. Will do and I let all know how it works. Our float is in the head of the harbor new the inlet of a freshwater stream. For some reason, it gets more barnacles and earlier then the floats further out the harbor.
Cheers!
Terry
