Wanted CD 14 sail
Walter Hobbs
Wanted CD 14 sail
Post by Walter Hobbs »
Please sell me your CD 14 sail.
You must have one somewhere. Check the attic. garage, basement, sail locker of your big boat.
I'm refurbishing my CD 14 and need a sail. Save me from having to make one myself.
thanks,
Reef at the mooring and go anyway.
Walter :roll:
Walter R Hobbs
CD 14 hull # 535, Grin
CD 27 Hull # 35 Horizon Song
Lincoln, RI
Dan Kretzer
Location: Cape Dory 14, Sumpwams River Rowing Skiff, RKL Cedar Strip Canoe, Alden Ocean Shell
Re: Wanted CD 14 sail
Post by Dan Kretzer »
Another forum member recommended Jim @ Sailor's Choice in Amityville, NY.
He recently made one for me. Finishing up the restoration on my 14. Hope to splash late spring.
Centerport, Long Island, NY
Walter Hobbs
Thanks Dan, I'll check it out.
Tried to take the middle seat out today, in the snow, so I could strip and varnish it in the basement. It will not fit past the gunnels. Apparently the good people at CD installed the seat before installing the gunnels.
Any suggestions?
Also did you repaint interior blue and white like original? Mine has been painted green and I plan to go back to the original look.
Walter :wink:
Walter R Hobbs
Lincoln, RI
Dan Kretzer
I would think it could slide fore or aft but maybe the shape of the hull prevents that? I've been working on mine for a year and a half and I don't remember if I took the seat board out before or after i removed the rails. I had to do extensive fiberglass work in cutting out the rear seat to replace the rotted transom core. I had a local boat shop replace the woodwork.
The hull is painted Oyster White and the interior is a custom color that I mixed myself that I call Oyster Buff.
I'll try to post a picture.
Dan Kretzer
Ready for wood sanding, varnish and rigging.
I'll go through my photos and post some to show the restoration process on the main message board.
That's a real beauty. :wink:
Dan Kretzer
Jim Walsh wrote:That's a real beauty. :wink:
Thank you. Lot's of work.
