I hate responding to my own request for ideas, but I had another one that might be helpful to someone on a CD30.
We forever were trying out different garbage bins on our boat. We tried the dry bin, but that took away a good 'dry' bin, which we do use. So I came up with the idea of using the space behind the companionway ladder..between the steps and the engine. I bought a small plastic trash can, about 16 in. tall, and perhaps 8 in. wide and 5 in. deep. Using two sheet metal screw with shoulder washers, I mounted this trash can on the inside of the engine compartment, against the back of the steps..as high as possible, and centered betweenthe two upper wood blocks that sometimes hold the steps in place. We line this trash basket with a 3 gallon trash bag, and it works great. We never accumulate that much stuff inthe trash can such that there is any smell to it (it disappears into the dinghy <alias garbage scow> when full).
Problem solved. This idea has worked for about 8 years now.
Cheers!
Larry DeMers
s/v DeLaMer
Larry DeMers wrote: Hi all!
I love little ideas that make jobs easier for us CD owners. I stumbled on this one last weekend, while changing the engine oil. I use a vacuum pump to suck out the oil from the engine via the dipsick tube. This is a fairly standard practice. Replacement of the oil seems to be the most irritating of the jobs involved in getting the job done. Up til now, I have been placing a hose in the oil filler hole, and pouring oil into a funnel, attached to the hose. Trouble is that the flow is slow, the funnel wanders, and oil is spilled almost everytime.
This time however, I placed the funnel close to the sliding doors under the companionway, and rotated the funnel until the little tab with the hole in it protrudes through the sliding door, and put a screw through the hole in the tab...on the back side of the sliding door.
This effectively holds the funnel tight against the sliding door, allowing you to use your free hand for wiping up the darn oil!
As I said..small stuff, but try it next time you change the oil, and see if it doesn't make the job a tad less of a task.
Now it's your turn to throw out a simple practice that makes working on our CD's less difficult.
Cheers!
Larry DeMers
s/v DeLaMer
Cape Dory 30 ~~~'On the hard' on Lake Superior~~~;^(
demers@sgi.com
