I need to replace the portlights on my 1973 Typhoon (Weekender) with bronze portlights. The port hole diameter is 4 1/4 in. The Spartan replacement portlights are 4 3/4 in diameter. Before I enlarge the port hole to fit the Spartan portlights...I'm hoping to find another supplier with the right diameter to fit my boat....Are there other sources for portlights which will likely match my dimensions.
Appreciate any suggestions.
StanC
Typhoon Portlight replacement
- Cathy Monaghan
bump...
....bumped back to the top by the webmaster....
CDSOA Associate Member #265
Greenline 39 Electra
Rahway, NJ
Raritan Bay
Rahway, NJ
Raritan Bay
Re: Typhoon Portlight replacement
I replaced the old plexiglass portholes on my typhoon. I used 4" bronze portholes from hear:
SailboatStuff.com
5456 Hazeltine Avenue
Sherman Oaks, CA 91401
Tel (818) 989-2233
Fax (818) 290-3393
Toll-free 1-877-447-2457
Toll-free 1-877-447-SAILS
www.sailboatstuff.com
orders@sailboatstuff.com
US$64.95 / EACH
Glass Diameter: 4" · Glass Thickness: 1/4" · Spigot O.D. (Cut-Out Size): 4-1/2" · Spigot Depth: 1/2" · Flange O.D.: 5-1/2" · Screw Size: 5/16" · Weight: 1.5 lbs. · Part Number: 140012 / 1192B
I did have to enlarge the holes which was not too big of a problem. I would suggest using a sanding drum on a dremel type tool. You can control the dust by holding a vacuum next to the tool. They came out fine. If you use the Spartan portholes just check that the depth of the flange is not greater than the thickness of cabin sides.
Good luck
Don
SailboatStuff.com
Tel (818) 989-2233
Fax (818) 290-3393
US$64.95 / EACH
Good luck
Don
Don
got mine 15+ years ago from ABI marine which you will find at sailboatstuff.com.
had to do a little fitting, but it definitely was not 3/4".
they now have a nice patina and have held up well.
I second the ABI port lights. I replaced the ones in our old Typhoon and it made for a very value added upgrade. Forget the cost but it really dressed up the boat and were maintenance free. My friend now has the boat and they still look great 15 years on.
