Leaking Portlight
- Shipscarver
"SOUL MATE"
Leaking Portlight
AQ year ago I replaced the rubber gasket that goes between the glass and the bronze port fixture. The leak continued. I replaced the gasket again. It still leaked. This time I pulled out the bronze portlight, and plastic covered the hole, power brushed the port hardware and removed the old gasket material (which was probably not the problem). That situation remains.
The new coil of round black hard rubber gasket material I had sitting in the shed turned out to be too thick. the port will not close (like a dummy I installed it and waited 3 days to be sure it was dry before trying to close the it where it is, sitting on my table).!
Does anyone have about 6 foot of of the round gasket material for a CD27 portlight so I can put it all back together without buying another big box of what will probably be the wrong stuff?
Shipscarver
Sailing the Florida Gulf
- Cathy Monaghan
Re: Leaking Portlight
Also, don't forget, when installing the new gasket, that the joint where the to ends meet should be at the top of the port and never at the bottom.
Cathy
CD32 Realization, #3
Rahway, NJ
Raritan Bay
Cathy
Rahway, NJ
Raritan Bay
CDSOA Associate Member #265
Greenline 39 Electra
Rahway, NJ
Raritan Bay
Rahway, NJ
Raritan Bay
I have some, but not sure if it is in the basement or on the boat. Should be able to check by the weekend, and will let you know.
Have you explored the possibility that the leak is from around the frame? rebedding when you reinstall it should cure that as well, if it is the problem.
Duncan Maio
s/v Remedy
CD27 #37
Bristol, RI
s/v Remedy
CD27 #37
Bristol, RI
- Joe Myerson
Re: Leaking Portlight--Surgical Tubing?
FWIW, when surveyor Norm LeBlanc spoke at last Saturday's Cabin Fever Lunch in Dover, N.H., he mentioned the portlight gaskets as something to watch for in boats as old as ours. He suggested that you could use surgical tubing of the appropriate size to provide a good seal when the gasketing material had worn out.
I don't know if anybody has tried this, but the tubing is probably easier to come by.
Just a thought.
--Joe
Just a thought.
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
Yes, and you can also experiment endlessly with sheet to tiller self steering with all the left over surgical tubing.Joe Myerson wrote:FWIW, when surveyor Norm LeBlanc spoke at last Saturday's Cabin Fever Lunch in Dover, N.H., he mentioned the portlight gaskets as something to watch for in boats as old as ours. He suggested that you could use surgical tubing of the appropriate size to provide a good seal when the gasketing material had worn out.
Just a thought.
--Joe
Seriously, Norm did mention this. I would think your local medical supply store would be happy to give up an inch or so of various sizes so you could test for the right fit.
- Joe Myerson
Hey Neil,Neil Gordon wrote: Yes, and you can also experiment endlessly with sheet to tiller self steering with all the left over surgical tubing.
Don't laugh. I've received some good ideas from another forum--and I think I can get it to work. (Yeah, you've heard that before.)
One of the secrets might be a bottle of good single malt -- not while under way of course.
--Joe
I wasn't laughing, just smiling.Joe Myerson wrote:Hey Neil,Neil Gordon wrote: Yes, and you can also experiment endlessly with sheet to tiller self steering with all the left over surgical tubing.
--Joe
