That charge controller I mentioned in the PM would be a good option with two separate banks..
Your batteries are not connected in series, either.Sea Hunt Video wrote:...The two AC Delco Voyager Group 27 batteries (M27MF) on S/V Bali Ha'i are NOT set up in parallel. They are in series and only connected in parallel via the Perko battery switch (OFF, 1, ALL, 2)...
The 12-Volt Bible for Boats is a clear, nonthreatening introduction to the 12-volt electrical systems used on small boats to power everything from reading lights to bilge pumps. This second edition is thoroughly updated with respect to modern batteries, breaker and panel design, alternative energy sources, and troubleshooting equipment, but it retains the fundamental simplicity that is the source of its enduring popularity (more than 100,000 copies sold).
Hi Robert,Sea Hunt Video wrote: The two AC Delco Voyager Group 27 batteries (M27MF) on S/V Bali Ha'i are NOT set up in parallel. They are in series and only connected in parallel via the Perko battery switch (OFF, 1, ALL, 2).
The cable connecting the two batteries together is BLACK and is believed to be the negative ground cable. A black cable goes from Battery #2 (neg) to Battery #1 (neg). A second black cable goes from Battery #1 (neg) to the engine block.
Sources report that Sea Hunt Video is still trying to trace some red wires that go from the battery up into the cabin.
Answered your PM...Brian2 wrote:Hello,
I installed the on/off/combine switch this summer, replacing a 1/both/2/off switch. I did this for two reasons: My panel and engine were not separated. On 1 (Start) or 2 (house) or both, voltage was supplied to my house battery, and to the engine. After a day or afternoon of sailing, when I started the engine to anchor or moor, I didn't like seeing the voltage drop on my electronics. I installed a 3A solar panel wired directly to my house battery; the panel easily keeps my house battery charged, and now I sail onto the mooring much more frequently, as I don't feel the need to motor for a while to recharge the house battery. And the house battery is truly isolated from the start battery. I now start the engine only using the start battery, and the start battery does not supply the panel. When I start the engine, I see no voltage drop in in electronics, or on the Link 10 monitor wired to the house battery. My house battery supplies the distribution panel, and my start battery supplies the engine.
My question is: When I installed the on/off/combine, I thought that combine was the same as both on a 1/2/both/off. Is that not true?
Also, one concern I have now is that both batteries are always on when the switch is on. I can't turn off the start battery when it is not needed. That means if I have some voltage leakage somewhere in the engine wiring, the start battery could end up dead overnight. Previously, with the old 1/2/both/off switch, I switched to 2 (house) when anchored, moored, or sailing, believing that as such the start battery was always fully charged. I have no reason to suspect any leakage, but things happen.
Our 80W Siemans panel, which then became Shell Solar and now Solar World cost $875.00 11 years ago. They still make the same panel and a quick search revealed it can now be purchased for $262.00.. That's a pretty big drop in price for a premium quality level panel..mike ritenour wrote:I keep reading in the trades that solar panels have reached a record low in price, due to dumping by China.
However, as I look around it does not seem to be the case.
Prices seem about the same as they always were.
Has anyone done any research on the cheapest and best panels currently on the market?
Tips on panels?
Recommendations?
Pitfalls?
Where they can be purchased?
Many thanks,
Rit
