PVC vs. EMT for winter-cover frame
- Joe Myerson
It's definitely time to start thinking and planning for haulout here in New England.
An article in this month's SAIL magazine got me thinking about building a frame for my winter cover, either out of PVC pipes (as described in the SAIL piece), or using EMT (electrical metal tubing).
Any thoughts on which would be the better option?
NOTE: I had been dubious about PVC here in snow country, but the design shown in the magazine is very robust--and the author is a Great Lakes sailor.
--Joe
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
Winter Cover
Joe,
PVC and EMT will both do the job. EMT is stronger. PVC can be bent by hand. You should use an EMT bender to prevent kinking the metal tubing. Using EMT, you can use one size smaller than PVC for the same snow load strength.
"If I rest, I rust"
Voting Member #490
Voting Member #490
- Bob Ohler
Photos and follow-up please.
Joe,
I'd love photos and a follow-up, both as your project progresses and when it is complete.
Bob O.
Bob O.
Bob Ohler
CDSOA Member #188
CD30B, Hull # 335
sv Aloha Spirit
CDSOA Member #188
CD30B, Hull # 335
sv Aloha Spirit
winter cover
I used PVC 1/2" x 10' sections bent over a 2x4 strongback that was elevated about 4' over the cockpit sole. The strongback was held up by vertical 2x4's fore and aft. Over the framework I placed a blue plastic tarp. I attached a flat 2x6 foot to the base of both vertical 2x4's and from both ends of the strongback I attached 1x4 braces parallel fore and aft. This provided stability to the rig and a framework for the tarp. We received a lot of snow last winter and the cover never failed. Of course, this was for a Ty daysailer but could readily be adapted to your larger CD. The 10' sections were long enough to make one full hoop on the Ty, but I fear you might need to glue sections together to get the right length. I thought about using EMT but liked the softer foot of the PVC. Just my $0.02.
Jim Buck
Member #1004
Member #1004
- tjr818
PVC
Here in Saint Louis we can get up to a foot of dense wet snow in a big storm. I have a winter cover from the Canvas Store for my CD27 so I do not fabricate a cover for Sláinte, my CD27. However I do have a small backyard pond that I cover every year with a net. The fine mesh net catches snow as though it were a solid cover. I have built four different models of my tent so far. I now use 3/4" PVC which can easily span in a 10' arc. It is easy to use, easy to cut, easy on any surface it rubs against AND it doesn't rust. There are fittings galore to help manufacture any cover you can fashion. Elbows, tees, reducers, and any combination of these that you can imagine. I would whole heartily recommend PVC.
- Joe Myerson
Leaning toward PVC
Thanks Tim and Jim,
I'm starting to lean toward the PVC option, because I can cut the stuff with a simple handsaw, and because there are 45-degree and T fittings, which is what I need for the structure shown in SAIL magazine.
That particular frame looks like it would take a lot of work to build the first time, but that it would hold, take down easily and save me lots of work in subsequent years.
I'm still trying to decide if I should try to re-use last year's shrinkwrap instead--I saved it and the wood strapping that the contractor used.
--Joe
--Joe
- bhartley
CD25D #184 "Pyxis"
CDSOA Member #785
PVC Cutters
Joe,
PVC pipe is cheap. Forget the saw and get the cutters. Best investment you will ever make. They have them at Lowe's and Home Depot in addition to other places.
http://www.homedepot.com/webapp/wcs/sto ... -202515847
I have made multiple cover frames using PVC and these are what you need -- along with the black zip (UV resistant) ties.
Bly
Bly
PVC
Joe,
We use PVC to support the heat shrink on the OMF CD 85D
We buy large coils of irrigation PVC and cut it for custom sizes with no couplings used.
We use stanchion bases which are the exact size to insert the arched PVC ends into.
We use a standard tubing cutter to get straight cuts.
"If I rest, I rust"
Voting Member #490
Voting Member #490
- Chris Reinke
- Location: CD330 - Innisfail (Gaelic for "A Little Bit Of Heaven on Earth"), Onset, MA
Joe - We purchased a winter cover from Fairclough, along with the EMT frame system. The frame is very robust and utilizes cast aluminum connectors, but I am sure other EMT connectors would be equally as effective. We hauled our CD330 today, and was able to install the frame and cover in about an hour. I would suggest you look at Fairclough's website to see how they do it, and compliment them by copying
Joe, I made a pvc arch frame 10 yrs ago and will be using it again after haul out. No connectors, it bends easily and attaches to the stanchions. A few 1X3's help support the arches from snow load.
For the 1st 5 years I re-used the same shrink wrap. Since I've been using green poly tarp which seems to last 3 yrs.
Duct tape and nylon ties are a requirement.
CD 30c #42
S/V "Bluesails"
+ 41.69989
-70.027199
S/V "Bluesails"
+ 41.69989
-70.027199
PVC
I also construct a frame out of PVC on my CD 28. However, I always have a problem placing the tarps around the side stays. I have an upper and two lower stays on each side. Has anyone ever undone the two lowers and attach them somehow to the upper to make it easier to place the tarps around them? I would think the mast would still be adequately supported for the winter with just the upper side stays. If there's any reason why this shouldn't be done, please let me know.
- Chris Reinke
Philip - We used the same method Jim suggested with our old canvas/PVC frame system. We just cut a small hole in the cover and one by one passed the shroud through the cover and re-secured to the deck plates. One point, we found the holes grew as the cover flapped or got snow loads so for the second year we sewed a small piece of backing canvas at each hole.
