Seeking Advice from Carolinas Fleet
- Warren S
Cape Dory 270 Hull #5
Washington, NC
As predicted, McCotter's rates are increasing after the big fire. If the other amenities were up to market standards, I wouldn't mind, however...
Can anyone advise as to other marinas in the area (Neuse river, Pamlico River, anywhere is game) I should inquire about moving my boat to?
Thanks!
Thanks!
Marina Recommendation
Warren-
We keep Miss E at Northwest Creek Marina, in Fairfield Harbor, downstream on the Neuse from New Bern. It's a great facility, well-managed, and protected, although you will be a good distance from Oriental and Pamlico sound. It was worth the trade-off for us, however, since their slip rates are more reasonable than other marinas. We've been there almost two years; you should check it out.
Richard
Richard
- Warren S
Washington, NC
Thanks Rchard
I looked this over, got some rates, and it looks like my top pick for now. The information I received earlier today was $1939.14/yr (10% annual disc.). Does that sound right? I'll be down there to look it over in the next week or 2.
NWC Marina
That sounds about right; is that figure based on Morveren's 27 foot LOD? I thought the minimum there was 30 feet, but they may have changed the policy.
Richard
Richard
- Location: CD 31 "Mystical" Hull #32 New Bern, NC Berthed at Pecan Grove Marina, Oriental, NC
- Warren S
Washington, NC
Thanks Dick and Richard
I spoke at length with John Cox (who also mentioned Grovner). Sounds great, but alas, I stil have two boys to put through college and trying to stay as close to $2k or under as possible. Presently looking at Blackwell Point as it is "under the bridge", but no amenities.
NWC is still in the running. I like that they meter the electricity rather than a fixed add-on fee.
Small marinas in Lower Broad Creek
Hi Warren,
You might want to check out two marinas near me in Broad Creek: Ensign Harbor (Nick Santoro) and Boone Docks (Paul Fairbanks) are both first rate facilities in the best hurricane hole around, an important consideration. Also, you are closer to open water at the mouth of the Neuse River.
To me, the open water is a biggy and my biggest bitch about NWC Marina as you are literally hours up the river w/o many closeby anchorages. Also, you may want to spend a weekend there overnight on the boat. You might be able to stand the live amateur bands and karaoke until midnite curfew but some people can't. The bandstand is immediately overlooking the marina. On the other side, Dawn and Bud are top notch dockmasters and the facilities are excellent.
Should you decide to go over your $$$ limit then check out Sea Harbour Marina as it is, by far, the place to be in Oriental. I believe there are slips available in the $770/qtr range.
Andy
Andy
s/v Rhiannon
"In order to be old and wise, one first must have been young and stupid ...
- Warren S
Washington, NC
Will-do
Thanks Andy. You and I are on the same page as far as location goes. I rejected everybody up on the Pungo for the same reason. I havent heard of Ensign Harbor, so I will collect information there. Boone Docks is on the short list.
I'm enamoured with Matthews Point Marina (Clubfoot creek). Know anything about them?
