RE: leftover gas
Jim Buck
RE: leftover gas
Post by Jim Buck »
Last year my 2 stroke outboard only used about 3 gallons of gas from my six gallon tank. I put fuel stabilizer in it but I'm kind of afraid to use it. I'd like to fill the tank with fresh gas and the proper oil mixture. Can anybody recommend what to do with the three gallons? I've thought of putting it in my truck but the oil in the gas worries me. Any experience or suggestions would be most appreciated. Thanks.
Jim Buck
Member #1004
Mike Wainfeld
Bayshore, NY
Old gas
Post by Mike Wainfeld »
I have a one gallon tank. I also use about 2-3 gal/season, and I've put 1/2 gallon in the SUV tank before with no problem. Don't know about 3 gal though.
ronkberg
Use it in your truck
Post by ronkberg »
Hi Jim, I mix the 2-stroke gas with the gas in my F-150 and have had no problems. I add it to a nearly full tank and pour in 1-2 gal of mixed gas. Too much could damage a catalytic converter, that would be a costly mistake. However, oily gas diluted within 15-20 gal of regular gas should not cause any problems.
That's my humble opinion.
Ron
Ron Kallenberg
Old Orchard Beach, Maine
Sailing in Saco Bay, Maine
It always goes in my 1950s Ford 8-N tractor. That things would burn just about anything and not care all that much.
Lacking a vintage farm machine the above advice seems sound enough, Steve.
Joe CD MS 300
Post by Joe CD MS 300 »
I use old gas in the lawn mower. Usually half and half old gas new gas.
Post by Russell »
I have a can of old gas that I have been trying to get rid of for awhile, living aboard full time means I dont have lawnmowers and such to stick it into. Have tried giving it away many times but of course no one wants it!
jim trandel
Location: '83 Typhoon Weekender, #1907 "Second Wind" Chicago Monroe Harbor
Post by jim trandel »
Burning the old 2 Cycle gas is a great idea, but where can one dump old gas without effecting the environment?
This is a good question in light of the ethanol issue
sfreihofer
Post by sfreihofer »
Since you used a fuel stabilizer, I would be inclined to mix fresh gas with the old gas and use it in the outboard. The biggest threat with old gas is by gumming up the carburetor. The fuel stabilizer would minimize that and the new gas would compound the cure.
A drop in octane rating may be a concern, but a two-stroke outboard is not a high compression engine, and the fresh gas should be adequate to prevent any knocking. If you notice any knocking, use a higher octane fuel for mixing.
The only other concern would be carbon build-up in the combustion chamber, but since a two stroke burns oil, I don't see that as a major concern, because it is inevitable anyway, and generally doesn't cause much trouble.
Stan Freihofer
1981 CD25 #794
Ft. Lauderdale
www.ReefRoof.com
That's my two cents.
Johnd
old gas
Post by Johnd »
Gas stations have a waste portal you can poor into, they may charge you a couple bucks.
I can see posts 50 years from now..."I had to reach all the way back behind the PBBF, (portable beer-brewer/freezer) to replace my hydrocell pack! WAPITA!
Jd
Godspeed 27
Chesapeake Bay
CDSOA member # 1325
