Freshwater hand pump recommendations?
Moderator: bobdugan
- Joe Myerson
Hi all,
While winterizing the freshwater system on my 25D last season, I discovered that BOTH Jabsco hand pumps had stopped working. The previous year, when I contacted Jabsco, I was told that that particular model had been discontinued and that repair kids were virtually nonexistent.
That means it's time to replace these less-than-useful pumps with something else.
What have other 25D users chosen as replacement pumps, understanding that there is limited space to install a foot pump, at least in the galley? There is room for a foot pump in the forward head compartment, but I'm not sure that I'm prepared to do the major glass work involved, at least not this season.
I'm probably looking at some kind of "flipper" design.
--Joe
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
I have one of these in my galley:
http://www.imtra.com/product/pumps_tank ... ws_60b.htm
Its very attractive and matches with the other brass hardware inside our CDs. Much classier looking then any other pumps I have seen.
![Image](http://www.imtra.com/images/products/products/WS60B_150.jpg)
- Joe Myerson
Thanks Russell
Russell,
That looks like a beauty--and it will fit nicely in the head compartment. I'm not sure there's enough vertical clearance for the piston in the cramped area that passes for a galley in my 25D.
Thanks!
--Joe
Thanks!
--Joe
- mahalocd36
We have one similar to Russell's but with a longer handle. I think it's this (or similar anyways):
http://www.defender.com/product.jsp?pat ... &id=155472
Melissa Abato
www.sailmahalo.com
www.sailmahalo.com
- Warren S
Cape Dory 270 Hull #5
Washington, NC
I have both!
I use Russels in the galley. A little olive oil on the shaft once or twice a season will make it so easy to pump that I never consider switching to an electric pump.
I use Melissa's for the vanity sink for the exact reason: the overhang clearance. It, too works like a charm with plenty of room. The handle you see in the picture can rotate to either side based on what else you have sitting on the vanity at the time.
Extremely pleased with both and will never have to buy another fawcet for the boat.
On the galley unit, I did not winterize it properly. The nipple/check valve assembly cracked and failed this spring, but I was able to secure a new one without a problem (Defender, I think, or Jamestown).
![Image](http://i93.photobucket.com/albums/l49/AmpTRookee/morveren03.jpg)
- Warren S
Washington, NC
Post script, FWIW
I selected the galley faucet (Russel's) because of it's low profile (pump cylinder is below countertop) which makes for better shipping of pots and pans to and from the sink after dinner. I did have to re-position the faucet to a new location, but was well worth the effort.
- Joe Myerson
Great suggestions!
Thanks guys,
I really like the classic looks of those two Imtra pumps. I'll have to do some measuring when I get back to the boat, it may be that I'll end up using Melissa's recommendation for the galley and Russell's for the vanity--or Melissa's for both.
And, Warren, it's nice to know that Defender has kits for their pump.
Best,
--Joe
Best,
--Joe
I replaced the galley pump with the Imtra (Fynspray) WS62. No room for a floor lever in the galley area so this pump is a good replacement for the old pump. I have to admit it was more costly than other pumps but it was worth it. The handle is longer which means more gallons per pump. The handle is able to be swiveled to any angle. The total throw of the handle requires that the handle be positioned slightly forward of the overhang of the bridgedeck.
- Joe Myerson
Foot pump
Jeff:
BTW, is there any way to access the vanity pump, other than by removing the tool drawer and working upside-down?
--Joe
It sounds like you've already done the measuring.Jeff G wrote:I replaced the galley pump with the Imtra (Fynspray) WS62.
I've fantasized about installing a foot pump in the forward galley compartment, where there is plenty of room for a foot pump. But I think I'll go with simplicity.Jeff G wrote:No room for a floor lever in the galley area so this pump is a good replacement for the old pump.
--Joe
Pump Access
"BTW, is there any way to access the vanity pump, other than by removing the tool drawer and working upside-down?"
I removed the drawer and unbolted the sink. With the sink out its easy.
- Joe Myerson
Re: Pump Access
Duh! I didn't even think of that back when I replaced the pump. But that was before I became a CDSOA member.Jeff G wrote:"With the sink out its easy.
--Joe
