Using a whisker pole
Doug Oliver
Bucks Harbor, Maine
Post by Doug Oliver »
The CD33 I bought last fall came with a forespar whisker pole and I have used it a lot this summer but I'm not sure I am using it correctly. The problem I seem to have quite often is the pole sliding down the line in light air or inconsistant air during the lulls. Is there some trick that I'm missing?
JWSutcliffe
Post by JWSutcliffe »
Use a topping lift to keep the pole up in place and prevent it sliding back to the shrouds. On my 31 its easy - I just swap the staysail boom topping lift to the whisker pole. On a 33 you would need to rig a separate topping lift.
Skip Sutcliffe
CD31 Oryx
Kevin Kaldenbach
reply
Post by Kevin Kaldenbach »
Run the lazy sheet over the pole to keep it next to the clew
Kevin
CD 31 "Kerry Ann"
kaldenbach.us
