Hello all,
I just finished applying Teak Guard coats 3&4 and am very pleased with the results. I know that Teak Guard can be removed with soap and water (what kind of soap?) but I have tape seepage and need some advice as to how to remove it from fiberglass right under the toe rails.. Anyone have experience with this issue?
JBA
teak guard
- henry hey
- Location: Former owner: CD25 - 'Homeward Bound' hull #711. Now sailing with C. Brey aboard Sabre 28 Delphine
Teak Guard
Hi,
We applied Teak Guard to the brightwork aboard Delphine (Sabre 28) this year. It was very easy to work with and therefore we didn't use tape. When wet, it does clean up with only water.
What you might try with the dry teak guard overspill is simply scrubbing vigorously with a hard brush. It is a beautiful and simple finish, yet it does not stand up to abrasion. It may give way with scrubbing.
- Henry
- Henry
Carefully...
The only thing that removes dried on TeakGuard easily is laquer thinner.
Use it sparingly, don't let it puddle or stand on your gelcoat or you will damage your finish.
But if you use only a little on a cotton rag and wipe it right off with a dry cloth, you should be fine. Nothing else works on TeakGuard as far as I know.
Diana
Diana
s/v aja
1977 cd25 #530
Fairhaven, MA
NE Fleet Member since 2002
1977 cd25 #530
Fairhaven, MA
