I'M LOOKIG FOR THE BRONZE CHAIN LOCKER CAP , COVERS THE DECK HOLE FOR THE CHAIN. ALSO ANY SUGGESTIONS FOR CLEANING THE BRONZE FITTINGS, I HAVE TRIED SEVERAL PRODUCTS WITH LITTLE SUCCESS.
AWJAMES@MIDOHIO.NET
BRONZE CHAIN LOCKER CAP FOR CD 28
Re: BRONZE CHAIN LOCKER CAP FOR CD 28
Hi Alex
Check the (where to look) section on this site. Spartan Marine is still in business in Maine at Robin Hood Marine. I bought the hook that screws into the bottom of that plate over the winter. It was for my CD 30. They should have what you need.Their number is 1-800-325-3287
Jerry
CD 30 CHELSEA ROSE
liasboat@aol.com
Jerry
CD 30 CHELSEA ROSE
alex james wrote: I'M LOOKIG FOR THE BRONZE CHAIN LOCKER CAP , COVERS THE DECK HOLE FOR THE CHAIN. ALSO ANY SUGGESTIONS FOR CLEANING THE BRONZE FITTINGS, I HAVE TRIED SEVERAL PRODUCTS WITH LITTLE SUCCESS.
liasboat@aol.com
>>ALSO ANY SUGGESTIONS FOR CLEANING THE BRONZE FITTINGS, I HAVE TRIED SEVERAL PRODUCTS WITH LITTLE SUCCESS.<<
If you're talking about making them shine, forget it. We've talked about that forever and the conclusion is you'd rather be sailing. Nothing works that won't start turning green by tomorrow morning.
Regards, Neil
neil@nrgordon.com
Regards, Neil
neil@nrgordon.com
I found a bronze chain locker cap for my CD28 at a West Marine store. It fit perfectly.
wesham0@pop.uky.edu
wesham0@pop.uky.edu
Re: refinishing bronze
I've made my bronze look nice (at least to my standards) by cleaning it slightly and then painting it with Cetol gloss. It takes a darker wet look and stays that way. I'm not sure about painting over green oxidized bronze since my bronze was not discolored. I'm also in fresh water and that may make a difference. Anyway, just my $.02
eghaley@twcny.rr.com
>>I'm also in fresh water and that may make a difference.<<
I've not done any scientific testing, but I'd suspect that's right. Is a different environment.
Regards, Neil
neil@nrgordon.com
Regards, Neil
neil@nrgordon.com
