revisiting gel coat
Mark Mel
revisiting gel coat
Post by Mark Mel »
My 77' cd27 has numerous cracks on top. The gel coat no longer has that bright glassy look either (even after compound and polish). I'm thinking that a full covering of gel coat or some other solution would restore the top side to a bright new look.
I read through the earlier posts but would like to know what a complete gel coat job requires. What needs to come off before this job get done ? Is gel coat the best answer ?
mmelaragno@aol.com
sloopjohnl
Re: revisiting gel coat
Post by sloopjohnl »
mark,
repair the cracks, clean the top and paint it with a good two-part epoxy paint. if you're not a spray painter, get a pro to do it. brushed or rolled on will never look good.
John R.
Post by John R. »
Mark Mel wrote: My 77' cd27 has numerous cracks on top. The gel coat no longer has that bright glassy look either (even after compound and polish). I'm thinking that a full covering of gel coat or some other solution would restore the top side to a bright new look.
Mark,
I believe after you do your homework on all the options you will come to the conclusion that a linear polyurethane topside refinish job is your best option from all perspectives.
Examples: Awlgrip, Imron, Porter, Sterling, et al.
Catherine Monaghan
Post by Catherine Monaghan »
Mark,
Bennett Marine has a couple of videos that may help -- a picture is worth a thousand words. Check out their <a href="http://www.bennettmarine.com/paint_fibr ... website</a>.
Fiberglass Repairs Made Easy
Volume 1: Fiberglass Repair & Gelcoat Damage
Covers grinding out damaged material, applying new fiberglass laminate, shaping to original lines and finishing.
54 min.
H617WS
$29.95
Volume 2: How to Repair Gelcoat
Learn to mix matching colors, fill scratches and voids, spray gelcoat and final finishing.
43 min.
H618WS
$29.95
catherine_monaghan@merck.com
CD32 Realization, #3
Rahway, NJ
Raritan Bay
<a href="http://www.hometown.aol.com/bcomet/real ... lization's Home Page</a>
