A thread on thread
- Joe Myerson
A thread on thread
Here's a question for all of you who do your own sewing:
In lieu of an expensive Christmas present, my sister, an accomplished seamstress, offered to restore my sail cover. It's a blue Sunbrella cover that's probably original to my 1982 boat. The stitching has deteriorated over the years, the Velcro is coming off and zipper is coming loose.
The major problem is with the thread.
My sister has a commercial-grade machine, so she can sew through Sunbrella. What I want to know is this: which type of UV-resistant thread should I order for her?
If she repairs the cover with UV-resistant thread, presumably I can get another 27 years out of this cover, by which time I'll be 88 and probably won't care.
--Joe
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
- David van den Burgh
Re: A thread on thread
Check out Tenara or Profilen thread. Expensive, but durable.Joe Myerson wrote:Here's a question for all of you who do your own sewing:
--Joe
Thread
I get my thread from www.sailrite.com
Not only do they have a good product, they have wonderful tech support. If you ever have any question, they can answer it. Check out their web site.
I use their UVR polyester thread. V-69 or V-92, 1 oz. cone (350 yds. or 250 yds.) will cost about $5 or $6. If you are only repairing a mainsail cover, that should be plenty, you won't need much.
The Tenara (Gore-Tex) thread they have listed comes on 1800 yd. spool for $139. It has a lifetime guarantee. To expensive for my taste. I don't think the fabric will last as long as the thread. It also requires some special handling due to the slickness. It requires smaller needles, and softer tension settings.
I don't mind re-stitching my seams, with the polyester thread, whenever they need it.
John & Nancy Martin
CD31 #85 "Carina" 1985
Sorry. When I read your post I thought you were specifically after a high-grade thread to be done with restitching. If that's not what you're seeking specifically, I second John's suggestion.
I'll be making new sail covers for Ariel this spring, and plan to use standard bonded polyester thread (V-92).
- John Danicic
sailrite
Ditto for John Martin's advice.
Sailrite is the best.
The VC 69 is strong stuff, You can't break it with your bare hands unless you want thread cuts. I have used it successfully with my 1946 Belina sewing machine on all sorts of projects, from sail bags to riding sails.
It be good stuff.
Using Tenara at that price is so pre Great Recession.
Sail on
John Danicic
CD36 - Mariah - #124
Lake Superior - The Apostle Islands
CDSOA # 655
It be good stuff.
Sail on
John Danicic
CDSOA # 655
- Joe Myerson
Thanks everybody
Sorry, I should have mentioned that I would probably order whatever thread I did buy from Sailrite. They have such high recommendations from everybody!
Since posting this, I've spoken to my sister, who says she has worked with Sunbrella before. Her machine is a professional one, but not a sailmaker's.
Anyway, I'll contact Sailrite and ask for their recommendation as to which UV-resistant thread to use.
Thanks again,
--Joe
Thanks again,
--Joe
- Matt Cawthorne
Hull # 79
27 years?
Hard to believe that the cover is that old unless it is only exposed to the sun for 2 months out of the year. My boat is kept on the Chesapeake and this winter I just made my third set of sail covers (the boat is a 1982). All have been Sunbrella. My last set was made with Tenara thread (actually it was the gore pre-tenara variant). The stiching looked like new on the sail cover, but the cloth itself gave up the ghost. You could actually see through it. It ended up tearing rather easily. If you are just going for a re-sew the cover will likely give up the ghost before the stiching goes bad no matter what thread you use.
Matt.
Matt.
- Joe Myerson
Maybe I'm wrong about the age
Matt:
You could well be right about the age of the sail cover--after all, the original owner of the boat seems to have kept her on the Gulf Coast, at least for a while.
But it is still an old cover that came with the boat. And the stitching has disintegrated, but the cloth seems to be holding.
The PO worked at a boatyard, and he seems to have picked up lots of miscellaneous stuff from other boats. The cover isn't a perfect fit, but it works. And, after my sister's restitching, it will work for a while longer. (OK, probably not another 27 years -- six years will do fine.)
--Joe
--Joe
I reckon V-69 is what you want and I recommend Sailrite to get it. I sewed up a main with two reefs and a jib for my old Typhoon with there kits including V-69 and they are both still going strong as my friend now has the boat. That was ten years ago. For our 33 I have re-stitched both the wheel cover and mainsail cover which are both easily 25 years old. Also sewed 35 feet of the genny leech when a nasty 45 knot passage blew it out. The V-69 worked well after I figured out the 60 year old sewing machine and I am happy with the results. Keep 'em going as long as possible I say.
A regular 16 needle should work with V-69 fine but she may need to just work a little longer at getting the thread tension right. Then away you go.
All the best,
All the best,
My preference
My preference is V-92. Most pro canvas guys use it or Tenara these days. I have notr used anything but V-92 on Sunbrella for a long time....
One reason I like 92 over 69 is that it handles better in a commercial machine and when punching through multiple layers tends to not break nearly often as 69..
Re: My preference
And that strength translates to greater chafe resistance as well, the most likely cause of thread failure.Maine Sail wrote:My preference is V-92. Most pro canvas guys use it or Tenara these days. I have notr used anything but V-92 on Sunbrella for a long time....
FLYING CIRCUS
Thread Brand
Hi:
Many sailmakers mention in their brochures that they use Heminway and Bartlett thread in their sails. It's a well respected brand. Sailrite used to supply Heminway & Bartlett thread when you ordered thread from them, but I was disappointed to receive a non branded "mystery" thread from them the last time I ordered. Probably a Chinese imitation.
You can get the real thing from Sailmaker's Supply:
http://www.sailmakerssupply.com/prod_detail_list/31
Tony Jeske
Tony Jeske
