Cored or Solid
JCLOUDR
Bella Dory
Belhaven, NC
Cored or Solid
Post by JCLOUDR »
I have a 33 power CD fly bridge. Question: Is the hull solid or cored? Is the solid below the waterline and cored above? Solid hull above and below?
John
jcloudr@sc.rr.com
Hey, it is for sale... cheap
tmsc
Post by tmsc »
John the info I have indicates solid frp hull with balsa cored deck and superstructure.
Lee
S/V Solomon Lee
David Perry
Post by David Perry »
The Cape Dory 33 Poweryacht was constructed with balsa core in the sides of the hull above the chine, and solid glass below.
Cathy Monaghan
Post by Cathy Monaghan »
tmsc wrote:John the info I have indicates solid frp hull with balsa cored deck and superstructure.
That's for the CD33 sailboat not the CD33 powerboat.
Cathy
CDSOA Webmaster
M. R. Bober
Can it be true?
Post by M. R. Bober »
Cathy
CDSOA Webmaster
You mean, Cape Dory made stinkpots? :wink:
Mitchell Bober
Sunny Lancaster (where folks with too much free time stir the pot), VA :wink:
CDSOA Founding Member
tmsc
Post by tmsc »
I stand corrected, but that is the info I had for the 33 MV apparently it was incorrect. Now that makes me question the accuracy of the ref. book. David is the coring the same with all the MV models or just the 33?
Lee
S/V Solomon Lee
JCLOUDR
Bella Dory
Belhaven, NC
Well ??
Post by JCLOUDR »
Does this mean the hull is coreds?
Total?
Just above the waterline?
Thanks !
David Perry
Cored hulls
The Cape Dory 30,33 and 36 powerboats were all cored with Balsa-core above the chine, or basically above the waterline. These are high speed vessels and keeping them as light as possible was important. Powerboats have large, flat topsides so rigidity was best handled by coring and not extra laminates.
As to the sailboats, the Intrepid 40 and the Cape Dory 45 were cored in their hulls using Airex.
AnnapolisMark
CD28 Powerboat Hull
Post by AnnapolisMark »
I've put holes both below and above the waterline in the hull of my '91 CD28 powerboat. The hull is solid all the way to the rubrail. The decks are balsa cored except solid at the bow forward of the anchor locker and around the cockpit. The 28 is a full-keel semi-displacement hull while the larger powerboats were planing hulls.
Mark Cline
CD28 FB #219
Brandywine
Annapolis, MD
JCLOUDR
Bella Dory
Belhaven, NC
Post by JCLOUDR »
My 33 is full-keel semi-displacement hull too. Great boat and I am selling her for $59,900. Great condition!!
JCLOUDR
Bella Dory
Belhaven, NC
Post by JCLOUDR »
Actually she is for sale for $59,900...
If you want a great boat at a great price this is it !!
Re: Can it be true?
M. R. Bober wrote:You mean, Cape Dory made stinkpots?
All part of some celestial plan, it seems, Mitch. If not for a CD Stink Pot owner starting this very message board, you'd be posting that on a bathroom wall somewhere instead of on the world wide web.
M. R. Bober
Re: Can it be true?
Absolutely true.
Also when RESPITE's shaft snapped, a powerboat towed us to the repair facility, and once a mouse pulled a thorn from my paw. :wink:
Mitchell Bober
Sunny Lancaster (where unusual things happen regularly), VA
AnnapolisMark
The 33 is a Planing Hull
Here is a quote from the Robinhood 33 specs "Clive Dent, noted Naval Architect of many Cape Dory models, designed the Robinhood 33 to perform in a variety of conditions. Her modified deep-V, hard chine hull gets up on a plane easily with minimal power. " The 28 is a soft chin true semi-displacement hull that was not designed by Clive Dent. He designed the boat from an existing hull design.
Mark Cline
CD28 FB #219
"Brandywine"
Annapolis, MD
