Fresh Water Cooling
- JWSutcliffe
Fresh Water Cooling
Has anyone converted a raw water cooled Volvo MD7A to FWC? Is there room in a CD30 to do this?
Yorktown, VA
Probably no benefit
An engine that has been fresh water cooled from new would benefit from having had a proper antifreeze with rust inhibitors circulating in it. However, any raw water MD7A will have had salt in it and on-going corrosion for 30+ years, and adding FWC now will not offset that. I have even heard that converting to fresh water will dissolve deposits in a raw water cooled block that could lead to leaks etc, but this may be myth.
I think the original European manufacturer of the Volvo kits still makes them and I have seen a couple over the years on eBay UK. New they are about $1500, but one could probably home-engineer something using a commercial heat exchanger for less. I thought about it for my boat but for the cost I can buy a spare used engine.
If you don't get any answers here, there are some marine diesel boards that may be able to help.
Michael
Michael
Easier just to fresh water rinse
I considered the same thing. However, I settled on just fresh water rinsing after each time I put the boat away. You can easily rig a valve and a T into the inlet, close the seacock and let it pump as much fresh water as you think prudent.
My MD7A has the optional fresh water cooling. I've never heard of the European kit Michael mentions, but that is not what Cape Dory used. The Cape Dory installation consists of a heat exchanger (Sendure), a simple pump (Jabsco), two pulleys and a v-belt (generic), a crude mounting bracket (custom) and some hose (generic). Last I knew, Sendure was still in business in Florida so it should be fairly easy to duplicate this setup and there should be plenty of room to do it on a CD30 where the front of the engine faces aft.
Having said that, I tend to agree with Michael that if your engine has had salt water coursing through its veins for the last 25-30 years, it's probably not worth the money or the effort to change now.
- Location: 'EVENING LIGHT' CD33 No. 38, Pine Isl. Bay, Groton, CT
Hi JW,
Try: Sen-Dure Products Inc; http://www.sen-dure.com/, 6785 N.W. 17th Ave, Ft. Lauderdale, FL 33309, sen-dure@att.net,
954-973-1260, 800-394-5112. Defender may carry their products; 800-628-8225.
But as above, its worth may depend on how long the engine has been in salt.
Good luck.
Good luck.
Fair Winds,
Leo MacDonald
Founding Fleet Capt., NE Fleet
Past Commodore, Member No. 223
A 'Cape Dory Board' supporting member ~1999 to ~2015
Leo MacDonald
- JWSutcliffe
FWC
Thank you all for the replies. While the engine is apparently a replacement and not as old as the boat (27 years), I really didnt expect to improve engine life with FWC. My primary interest was in getting hot water away from the dock.
Only got this boat a week ago, after 30 years of admiring Cape Dorys. I guess I will just live with cold water for this season.
Skip Sutcliffe
CD31 Oryx
CD31 Oryx
Re: FWC
I'd live with the boat for a while before adding all the comforts of home. Start listing wants and needs so that you can prioritize where you spend your time and your boat bucks. Don't forget to leave some time and money for sailing, too.JWSutcliffe wrote:Only got this boat a week ago, ...
I've had LIQUIDITY for more than 10 years and she remains a basic boat. No hot water, no pressurized water, no AC current, no air conditioning, no flat screen TV, no stereo, no washer/dryer, no microwave, no fridge/freezer. Many of those are items that at one time or another are the subject of threads that starts, "My ______ doesn't work! The season is half over and _____________."
Simple Hot Water Solution
If you are simply looking for hot water, then consider a Sun-Shower. It REALLY works. I usually tie it down on deck between the teak handrails, and by late afternoon the water is hot enough for showers, dishwashing, etc.
- Joe CD MS 300
Re: FWC
Neil, glad you didn't say "no beer". That would translate in to "no crew" for sure.Neil Gordon wrote:JWSutcliffe wrote:Only got this boat a week ago, ...
No hot water, no pressurized water, no AC current, no air conditioning, no flat screen TV, no stereo, no washer/dryer, no microwave, no fridge/freezer. "
Joe
Re: Simple Hot Water Solution
It holds more water and lasts longer than you think, too.Bill Goldsmith wrote:If you are simply looking for hot water, then consider a Sun-Shower. It REALLY works. I usually tie it down on deck between the teak handrails, and by late afternoon the water is hot enough for showers, dishwashing, etc.
Re: FWC
Joe,Joe CD MS 300 wrote:Neil, glad you didn't say "no beer". That would translate in to "no crew" for sure.
That's never a problem. You might have to drink it at bilge temperature, but beer is available. Single malt, too, is always on board.
- JWSutcliffe
Creature Comforts
Neil:
Not all the comforts of home - just the bare minimum that my spouse/crew/boat-fund-provider is looking for. We have a solar shower already, its functional but limited for 2 persons needs.
But you are all correct - I didnt buy this boat as a second home, I bought it first and foremost to sail. After having gone over to the dark side for 10 years with a powerboat, I am thrilled to be back on a sail boat, especially one as capable as this.
Re: Creature Comforts
How about his and hers solar showers? That might eliminate the limit.JWSutcliffe wrote:We have a solar shower already, its functional but limited for 2 persons needs.
I'm really not suggesting that you not add comforts and modifications. It's just that I'd live with the boat for a while and see how you adapt over time. Your priorities might change.
