Installing tack hook for reef point
mgphl52
Post by mgphl52 »
OK! Pictures will be made!
Have great weekend everyone!
mgphl52
Post by mgphl52 »
Oops... Yes, I did remember to take the camera, and Yes! I put the reef in and took pictures along the way. We even sailed all afternoon with the reef, didn't really need it but we still did 6~7 knots and KAYLA had her way with yet another sailing virgin. By the way, the lady did an awesome job on the helm fo an hour or more!
OK, now for the bad news: I left the bloody camera on the boat. Since it's 3 hours round trip (AKA: about 9 gallons of gas), I ain't going back till next weekend at the earliest. Sorry folks...
-michael
mgphl52
Photos... finally
Post by mgphl52 »
Here's the line made from 1/4 (or 3/16) dacron with a bowline that is also whjipped and lashed:
[img]http://sv-kayla.org/KAYLA/misc/reef-lin ... f-line.jpg[/img]
To set, I push the loop thru the grommet from the starboard side and go under the boom, up to and back thru the loop. Here it is loosely in place:
[img]http://sv-kayla.org/KAYLA/misc/reef-lin ... tioned.jpg[/img]
This is a starboard view after tightening:
[img]http://sv-kayla.org/KAYLA/misc/reef-lin ... rboard.jpg[/img]
And this is a port view:
[img]http://sv-kayla.org/KAYLA/misc/reef-lin ... t-port.jpg[/img]
Lastly, here is a view of the line cleated off over our spare jib halyard:
[img]http://sv-kayla.org/KAYLA/misc/reef-lin ... leated.jpg[/img]
OK, it ain't exactly "pretty" - but it works... :D
-michael
boom2it
1983 CD Typhoon
#1910
City Island, NY
thanks
Post by boom2it »
looks straightforward and simple, thanks for taking the time to take and post the pictures.
Gene
Gael Force
City Island NY
83 TY WKNDR
mgphl52
Post by mgphl52 »
Hi Gene,
This should be easy to adapt to a Ty as well.
One recommendation for the Ty is to buy an extra slide stop and keep it under your boom.
This has two purposes:
1) it'll keep the boom from dropping down when you lower sail or reef;
2) it's a handy spare for when the upper stop goes swimming...
Yep! been thar dun that! :oops:
Enjoy!
-michael
Rebinva
Thanks for the pictures!!!!!!!!!!!!!!
Post by Rebinva »
I am going to try something very similar.
Judith
Michael/KAYLA crew
Post by Judith »
Thank you for taking the time to take/post pix. Very informative!
Judith
mgphl52
Pictures correctd...
Post by mgphl52 »
Sorry folks, but some file maintenance on the website broke the links to the photos. All corrected now.
-michael
boom2it
1983 CD Typhoon
#1910
City Island, NY
ahhhh I see
Post by boom2it »
That gives a much clearer picture. I tried your method this past Sunday, similar but it was my first try and not as neat, but it worked. Now I will have better idea when I reef again. I also like Sea Hunt's idea of leaving the line in place with a figure 8 on the opposite side of the loop to hold it in place so it is always there when needed.
Gael Force
City Island NY
83 TY WKNDR
mgphl52
Post by mgphl52 »
Keeping the line attached does have its advantages, but I use the same line for both reef points. I definitely do not want two of them hanging there!
My reef line also has a "dedicated" spot in the cabin that I usually reach easily and quickly (on top of the rarely used stove... :? ). We also raced KAYLA pretty hard the first few years and always tried to keep things un-cluttered, especially top-side. Extra lines hanging from the main could get tangled or just cause "noise" I wouldn't want to put up with - but I do still enjoy listening to the gentle hum of my free-wheeling three-bladed prop! :D
Enjoy!
-michael
Bill Goldsmith wrote:SeaBelle is right, the hook should be through-bolted at the gooseneck. The bolt should go through the portion of the gooseneck casting that fits into the boom. Just be sure not to drill the hole in a location that would foul the bolt attaching the casting to the rest of the assembly.
Does anyone know how far that casting extends into the boom?
I am ready to try this on my CD27.
Here is a photo:
jfischgrund
Re: Ty reef hook
Post by jfischgrund »
Gary H wrote:I have been thinking about installing a reef hook on my Ty. I read somewhere that instead of using a hook, one could tie a line to the reefing grommet and then just haul down on it and cleat it. I have an extra cleat on the base of my mast. I am trying to visualize if this would work or if it would restrict the boom from swinging in any way.
jfischgrund
Re: Installing tack hook for reef point
New at this and I tried to post before but don't see it so am trying again.
I have a stainless pad eye on the port side of the mast, I hook a cunningham hoo with a line on it into it and then the line up through the cringle and down to the cleat at the base of the mast on the starboard side. It works with both reef points and does not restrict boom movement. Seems to work well on a CD 27.
gates_cliff
Post by gates_cliff »
jfischgrund, that's exactly what I did on my CD 27 as well. First time I was rigging the boat, approx. 10 years ago, I found the pad eye on one side and cleat on the other and seemed like it would work and that's what I've used since.
Cliff
― André Gide
