OK. On ut last trip, I noticed that upon starting the engine, the volt meter has begun to take it's sweet time before responding with a proper output volyage (> 12v). It rests at 0 or near-0 for as much as 5 minutes before springing into action.
Before I start problem isolation, has anyone seen this before and could it be a slam-dunk solution?
thanks
Charging system taking holidays
- Warren S
Cape Dory 270 Hull #5
Washington, NC
![Image](http://i93.photobucket.com/albums/l49/AmpTRookee/morveren03.jpg)
Not Charging
Warren,
Maybe you are charging but the ship's meter isn't showing it. Do you have a multimeter? If you haven't had any low battery trouble recently, it's a good chance that the battery is being charged.
Also:
Check belt for tightness. Look for black dust near belts
Check for loose or corroded terminals both at alternator and panel meter.
Check all grounds. You probably have a good engine ground if the engine cranks okay.
Check all wiring for poor connections at battery taps, feed to panel.
Check battery for clean, bright terminals with no corrosion.
Also:
- Warren S
Washington, NC
Those are now on the list
I'll run down all those areas. I can't wait to go through the wire harness. in general. when we took possession I recall the battery check meter used to go off the scale while a multi-meter registered a normal 12v. Just moving some terminations around in the switch panel and disconnecting a shorted anchor light resulted in normal operation of the meter - now I trust it is accurate (this is the check meter in the switch panel, not the charge meter in the cockpit).
