CD 27 mast dimensions
San Carlos, Sonora/Kanab, Ut.
Can anyone tell me what the circumference of a CD27 mast is? I'm in the process of ordering a new mainsail cover from JSI.
- Ron Churgin
- Location: "Courtship" Allied Princess Cutter,Oceanside, NY
mast dimension
Doug,
Just measured mine for you. 16-1/4" by my tape measure, just above where my cover sits. It appears to be straight most of the way up.
Ron
Ron
Ron Churgin
- Mike Raehl
- Location: CD27 #151, Roberta Jane III, Belmont Harbor, Chicago
I measured my mast circumference when building a Sailrite mainsail cover but did not adequately allow for the main and spinnaker halyards. Fortunately, there was enough extra fabric to correct the error. So don't forget to include any halyards and cleats that will be covered by the throat of the mainsail cover.
Mike Raehl
- Warren Kaplan
Mast mounted winches too
My mainsail cover got pretty warn from "pressure" over mast mounted winches covered by the fabric. The sailmaker then put some reinforcing chafing patches over the area where the cover goes over the winches. Also something to consider when measuring and building the sailcover.
CD27 mast dimensions
Thanks guys. It is difficult to upgrade and work on your boat when it is in Mexico.
