My mainsail has no cunningham. Neither the luff nor the foot are as tight as I'd like them; i.e. they have a little play in them. I've tugged on the halyard til I can tug no more. The little block in the outhaul doesn't really afford all too much purchase in drawing the main aftwards.
Also some spider-cracks are beginning to appear on surface of hatches in cockpit and I think UV light beginning to impact surface of hatch over cabin. Should I sand and paint?
Any advice on either of these problems much appreciate...oyster2
No cunningham sailor w/ cracks beginning to show on hatches
FLYING CIRCUS
Cunningham
Hi:
I suggest you check with a local sailmaker about adding a cunningham eye in the main. I wouldn't think that it would be too expensive and would be well worth it.
As far as the outhaul is concerned, yes, it's almost impossible to adjust once you're under sail. I preadjust at the dock based on curent wind conditions before going out.
Sure, I'd paint the hatches. If the hatch surface is non skid, you may want to wire brush rather than sand before painting.
Good Luck,
Tony Jeske
CD-28 #365
NO REGRETS
San Diego
Good Luck,
Tony Jeske
CD-28 #365
NO REGRETS
San Diego
Bolt rope
As has been mentioned here before, sometimes the boltrope shrinks and you can't tension the foot of the sail as a result. Your sailmaker can fix this. If it's not that, cleaning and lubricating the track might help reduce friction. You can always add purchase by adding a block for mechanical advantage.
bolt rope?
is the bolt rope you refer to also called a downhaul; if so, this line is tight. Maybe the main halyard (which is only 2 yrs old) strechtes out after the main is raised. i've suspected but can't prove this theory without I think having a new halyard installed. If the bolt rope is neither of these lines, it's something I don't know about and could definitely represent the source of the loose fitting sails.
The give along the foot is there when the sail is raised; it's not a case of the outhaul easing up under sail.
Many thanks for all the suggestions. Will get to the scrubbing & painting...oyster
Bolt Rope
The bolt rope is sewn into the foot of the sail. It's not a control line. If it shrinks, you won't be able to tension the sail along the foot since you'll be at the limit of the rope before the sail gets stretched out.
